clifford wizard data cable
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67003
Printed Date: May 13, 2026 at 1:41 AM
Topic: clifford wizard data cable
Posted By: pilotboy
Subject: clifford wizard data cable
Date Posted: November 25, 2005 at 4:29 PM
  Hello, on the data cable there's a circuit board with a two wire female plug coming out of one end; can anyone tell me what the two wire female plug is used for? Dose this have to be hooked up before I can get online? It won’t connect with my alarm now.posted_image I have the Intelliguard 9000 with intellistart 4
Posted By: pilotboy
Date Posted: November 25, 2005 at 4:35 PM
 Hello, on the data cable there's a circuit board with a two wire female plug comingout of one end; can anyone tell me what the two wire female plug is used for? Dose this have to be hooked up before I can get online? It won’t connect with my alarm now. I have the Intelliguard 9000 with intellistart 4 posted_image
Posted By: pilotboy
Date Posted: November 26, 2005 at 8:49 PM
I cant connect to my alarm, I keep getting error 2, any help would be great..
Posted By: scirocco16v
Date Posted: November 28, 2005 at 6:45 PM
That plug is indeed for powering the control unit if doing benchtop programming.  If the alarm is installed and powered up it is not needed for programing.  By the way the alarm does need to have power on the red 18ga wire to be recognized by cliffnet as well as the intellistart.
Posted By: pilotboy
Date Posted: November 28, 2005 at 8:19 PM
Thank you, got it working. No I just need to get the intellistart 4 working.
