2005 Volkswagen Jetta RS
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67057
Printed Date: May 12, 2026 at 2:45 PM
Topic: 2005 Volkswagen Jetta RS
Posted By: platinumshift
Subject: 2005 Volkswagen Jetta RS
Date Posted: November 26, 2005 at 2:45 PM
Installing a RS into this vehicle atm. Just a quick question. Using a 556U as the bypass module, where is the Factory Transeiver Module? If you have done this b4 and dont tap into this wire then that answer is fine as well. Also does this vehicle need a keysence to be hooked up? If so, which wire? none is listed on directwire.
Date Posted: November 27, 2005 at 8:28 AM
Alright - I am unable to get the vehicle to start unless I hold the key pointing towards the key barrel. So this means that it wont work with the 556U, using the loop - any idea where the box is that I have to tap into to send the signal?
Posted By: cloneman315
Date Posted: November 27, 2005 at 3:02 PM
use the factory key ring just cut the wires and put the 556u in line ,read the instrucions on the 556 u box it works very well,vw need the loop on the very outside to work
