what remote starter for Chevy 2005 3/4 HD
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67076
Printed Date: May 12, 2026 at 7:13 AM
Topic: what remote starter for Chevy 2005 3/4 HD
Posted By: flykelley
Subject: what remote starter for Chevy 2005 3/4 HD
Date Posted: November 26, 2005 at 6:39 PM
Hi Guys I got a 2005 Chevy 3/4 HD and want a remote starter. I am in Michigan north of Detroit. What brands do you suggest? I have power locks and keyless enrty from the factory. I am looking for a long range starter that will work through cement block and steel at abour 700 ft. Most of the one's I have seen say they work up to 1000 ft. The two that I have owned didn't work close to that number even on a flat open parking lot, maybe 500 ft at best. I was quoted a price of $450.00 installed with a security system, the security system I can live without but I do want starter conformation. I also do not want a large remote, would like to keep it to the size of the remote from the factory. Thanks Mike
Posted By: cntrylvr79
Date Posted: November 26, 2005 at 6:50 PM
I can't complain about DEI systems. The only time you might run into a range problem with one of them is if the installer bundles up the excess antenna cable. I put these things in all the time and customers are always amazed when I start their car standing about 500 feet from the shop with the bay doors closed. ------------- Cause I'm So white and nerdy...
First Class Certi-fried installer
Posted By: mo12v
Date Posted: November 26, 2005 at 8:39 PM
Check the OMEGA Line or MICRO........ OMEGA has 2 New ones that DO NOT have LCD, but have 2 Way Confirmation & other stuff ........... MARS 22 & MARS 33 with MARS - 03 Upgrade on either Also, all conditions for Remote Start are different.......A Remotes Start on one persons Vehicle in the same building may NOT work on a different Vehicle in the same building..............
------------- MO
Posted By: cloneman315
Date Posted: November 27, 2005 at 3:10 PM
if u want the best out there and especially for range check out the 900 mhz or 2wss from compustar,nothing compares to them
Posted By: KarTuneMan
Date Posted: December 02, 2005 at 2:20 AM
I have never understood why range ( like a mile or so ) could ever be an issue.....my goodness. If you cannot see the vehicle, why would you need to start it? Buy your batteries at Costco...... -------------
Date Posted: December 02, 2005 at 9:02 AM
Because I work in a building without windows, can't see my truck from where I work. I like a warm truck at 2am,and I work about 300 ft inside the building. Thats why you need a remote starter that has a good 1000 ft range, which means you will need one that claims it good from 3000 ft. Regards Mike
Posted By: kgerry
Date Posted: December 02, 2005 at 9:18 AM
look for a good LCD 2 way unit from either Directed (Clifford, Viper, etc) Astro or Compu... these are the 3 best and most reliable units out there... do your own research and chose the model you feel best suits your needs..... ------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Date Posted: December 02, 2005 at 9:41 AM
Hi Guys I had a guy quote me a price on a Code Alarm remote starter with alarm,$450.00. The compu was quoted at $625.00 any thoughts on the code alarm? They claime this code alarm is the same as the compustar,Im having a hard time beliving that. Anyone have any dealings with a code alarm? Regards Mike
Posted By: kgerry
Date Posted: December 02, 2005 at 1:30 PM
i refuse to allow the product in the building and i used to be a code alarm dealer.... i havent dealt with them since they were bought by Audiovox, but the older Code product was absolute trash.....
Owner/Installer
Classic Car Audio
since 1979
Date Posted: December 02, 2005 at 3:24 PM
code alarms suck, buy the compustar and be done with it
Date Posted: December 04, 2005 at 12:53 PM
Compustar, or Astro..... -------------
