05 magnum, 791xv
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67169
Printed Date: May 12, 2026 at 5:23 PM
Topic: 05 magnum, 791xv
Posted By: anickle
Subject: 05 magnum, 791xv
Date Posted: November 28, 2005 at 1:09 AM
First time with an 05 magnum.  Doign 791xv, had everything wired in but it will not stay running.  We used a 555c and it seemed to program no problem.  We had tach ,remote and security all learned.  Start the car, it cranks runs for about a second and then shuts down.  I have try 3 different resistances for both starter and acc.  I have also tried a 556u.  All with the same end result.  I a curious what it sounds like to you guys/gals.  Is it a security issue? or a resistace issue? Thanks in advance
andrew nickle
Posted By: redpeppers
Date Posted: November 28, 2005 at 2:45 AM
sounds like a tach problem.....if u look in the install guide there is a shut down diagnostics.....it will tell u (from blinks of the LED) why the remote start shut down.......
Where theres is a wire there's a way.
Posted By: gus1
Date Posted: November 28, 2005 at 10:31 AM
Hey Andrew....
555C doesen't work on there... don't worry though. It's down here right now. We're fixing the door locks, and programming a 556c :-)
I'll call you.
Gus
