791xv remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67199
Printed Date: May 13, 2026 at 3:22 AM
Topic: 791xv remote start
Posted By: COVETTE03
Subject: 791xv remote start
Date Posted: November 28, 2005 at 2:18 PM
I need help with my remote start. everything was working fine and now all of a sudden it won't remote start. it sends and then recieves really fast but notihng happens. Ive checked the fuses and everything and I can't seem to find what is wrong. All I was wondering is if the unit for remote start did charge (like it said in the book, if you have the fuses in before connecting to the brain) is there any way to fix that or do i just need to get a replacement.
Posted By: infinkc
Date Posted: November 28, 2005 at 2:30 PM
might try re-learning the tach
------------- There are 10 types of people in the world, ones that understand binary and ones that dont.
Posted By: Teamrf
Date Posted: November 28, 2005 at 11:10 PM
Check the remote start diagnostic on the unit...compare the number of blinking lights and see what it is doing.
------------- ~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: JWorm
Date Posted: November 29, 2005 at 12:43 PM
Two probable causes of the symptom you are describing:
Did you install the on/off switch? Make sure its still on.
Did you install a hood pin? If so, open the hood and push down on the switch manually (or unplug it) and then try to remote start it again.
Date Posted: November 29, 2005 at 5:46 PM
what excatly is the on off switch? Is this the saftey switch for my e-brake or what. I tried the hood pin before and it didn't work so i just unhooked it. The only reason why I think it became "charged" was because at first i checked the connection and it became disconnected slightly with the two fuses still in I fully dissconnected the remote start from the brain and then I connected them togeather within 10 seconds.
