Keyless Entry 2001 Toyota Rav4
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6744
Printed Date: April 01, 2026 at 4:57 AM
Topic: Keyless Entry 2001 Toyota Rav4
Posted By: digger
Subject: Keyless Entry 2001 Toyota Rav4
Date Posted: December 15, 2002 at 7:59 PM
I am fitting a Commando KL-455 keyless entry to a 2001 Rav4.
I have everything in place and the system is producing door lock and door unlock outputs. I have the drivers kick panel removed and have located the multi-pin plug fed by the drivers door locks. I have found two wires that produce an output when the key is used to operate the lock. The colors of the wires do not match the Commando information and are the second pair down counting from the top. Both are smaller gauge wire than the others.
Basically the unit functions fine, with the park lights and the Commando's red LED sensing locking/unlocking, yet there is no action from the locks.
I can only think that I have got something fairly fundamental wrong. Any help would be great.
Digger
Posted By: Velocity Motors
Date Posted: December 15, 2002 at 8:15 PM
POWER LOCK--------------blue/white          |-  | @ integration relay
POWER UNLOCK---------blue / YELLOW         |-  | @ integration relay
The target wires above are what I have for the RAV4. It is a (-) trigger wire so all that is needed is a (-) pulse from the alarm system.
