04 Dakota astrostart
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67536
Printed Date: April 30, 2026 at 12:59 AM
Topic: 04 Dakota astrostart
Posted By: *theone*
Subject: 04 Dakota astrostart
Date Posted: December 03, 2005 at 2:30 AM
can anyone tell me where the "ground out while running" goes from an atsrostart 1105u?
Posted By: Geeque
Date Posted: December 03, 2005 at 8:19 AM
Ground out while running normally goes to an optional bypass module, usually if the vehicle your working on has a factory security system and you need to bypass; you'd use this wire to hook up security bypass.
Gary Kline
MECP Master Technician
Posted By: Velocity Motors
Date Posted: December 03, 2005 at 8:43 AM
Only if the Dakota uses a GRAY key will you need a bypass module. If it doesn't have a GRAY key, then you won't need this wire at all ( unless you want to use it to bypass your clutch switch if it's a manual transmission truck ).
Posted By: *theone*
Date Posted: December 03, 2005 at 9:56 AM
thanks guys, the truck has the gray key and I'm using the om-chrysler-1 bypass. The bypass doesn't have a "- when running " on it and the wiring chart doesn't mention it.
once again, many thanks
Posted By: *theone*
Date Posted: December 04, 2005 at 12:13 PM
hey guys,
the starter is in, the vehicle will start then quit within 2 seconds when remote started. I have checked and rechecked the wiring, I suspect a problem with the OM-chrysler-1 bypass. Is this what happens when the bypass is faulty or not programmed properly?
Posted By: KarTuneMan
Date Posted: December 04, 2005 at 12:22 PM
The OM Chrysler 1 is "plug n play"......no hard wiring.....don't ya love Astroflex.....
Posted By: *theone*
Date Posted: December 04, 2005 at 12:34 PM
what's the trick to removing the tilt lever on the 04 dakota
Posted By: Geeque
Date Posted: December 04, 2005 at 12:36 PM
Can't u manuever the bottom part of shroud around the tilt lever.
Gary Kline
Posted By: *theone*
Date Posted: December 04, 2005 at 1:13 PM
nope
Posted By: gus1
Date Posted: December 04, 2005 at 1:50 PM
Pull towards steering wheel....
Gus
Posted By: *theone*
Date Posted: December 04, 2005 at 5:21 PM
Thanks Gus.
I wasn't quite sure so I thought I'd ask and you were 100% correct.posted_image
Posted By: *theone*
Date Posted: December 05, 2005 at 2:29 PM
Turns out the om-chysler-1 was the problem, swapped it out and the truck ran fine.
Posted By: *theone*
Date Posted: December 11, 2005 at 10:17 PM
Hey guys,
Here's one. The key chime is going off when the key is switched back to "OFF" after vehicle has been running, but before the door is opened. The doors were hooked up through the alarm arm/disarm. Is this normal or is there something I'm not doing?
Ciao
