compustar 3000R/S 2005 Suburban
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67573
Printed Date: May 01, 2026 at 7:12 AM
Topic: compustar 3000R/S 2005 Suburban
Posted By: rickgood
Subject: compustar 3000R/S 2005 Suburban
Date Posted: December 03, 2005 at 4:39 PM
I am installing this compustar 3000 remote start into this 05 Suburban and need confirmation about hooking this 2nd ignition. This comes with a prewired relay that can be used for 2nd ignition. Does this get hooked up to the white ignition wire? Thanks Rick
Posted By: KarTuneMan
Date Posted: December 04, 2005 at 1:15 AM
Yes sir..... -------------
Posted By: Velocity Motors
Date Posted: December 04, 2005 at 11:12 AM
Just to clarify that you have to hook up the BLUE wire from the relay and then hook up the VILOET wire off the relay to the GREEN wire at the CN2 harness.
------------- Jeff
Posted By: rickgood
Date Posted: December 07, 2005 at 10:35 PM
There is no green wire on the CN2 connector. Rick
Posted By: jacqueslacombe
Date Posted: December 08, 2005 at 1:07 AM
Hi! I think the 3000 platform is already prewired for 2nd ign and the white wire is for ACC the green is the IGN
------------- cocolaboy
Posted By: rickgood
Date Posted: December 08, 2005 at 11:22 AM
yes, the relay is prewired. It has 2 reds to bat, 1 purple & 1 blue. I assume the blue goes to the white 2nd ignition but where does the purple go to? Rick
Posted By: forbidden
Date Posted: December 08, 2005 at 2:57 PM
The purple is a trigger line that makes the relay be a second ACC, second IGN or second starter depending on the wire that it is hooked to on CN2. As Jeff correctly pointed out above, hook this wire to the green ( - ign out) on the CN2 harness. The CN2 harness has 5 small wires in it and it is the next harness right beside the main harness.
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: rickgood
Date Posted: December 08, 2005 at 3:30 PM
thank you. i see it now. Rick
