2000 silverado, looking for factory arm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67599
Printed Date: May 09, 2026 at 8:32 PM
Topic: 2000 silverado, looking for factory arm
Posted By: redpeppers
Subject: 2000 silverado, looking for factory arm
Date Posted: December 04, 2005 at 12:09 AM
i have found disarm ....i am hoping that someone has found a factory arm wire .....so far the only way that i have found to arm the factory security is the factory keyfab.  thanks
Shawn
Where theres is a wire there's a way.
Posted By: Mike M2
Date Posted: December 04, 2005 at 7:31 AM
I'm pretty sure there is no other way to arm it other than the factory remote....
Mike M2
Tech Manager
CS Dealer Services
Posted By: Velocity Motors
Date Posted: December 04, 2005 at 10:38 AM
You can arm the system by grounding the driver's door pin ( TAN at the BCM ) while locking the doors. This will also shut down the RAP system for you. Use the REARM wire to the door trigger and this will work.
Posted By: jacqueslacombe
Date Posted: December 04, 2005 at 2:35 PM
posted_image  Hi! jeff is right      negative trigger the driver door pin  and lock the door the system will arm   But i dont know what type of remote stater you installe   once it's armed and you press again the lock button you might  trigger the alarm.
PS.with autostart  you won't have that problem.
cocolaboy
