I am installing an Omega Max E/remote start/keyless entry system. I'm almost done with the connections, but i have a problem the arm/disarm wires to the alarm require a negative pulse input. Where should i look for this? The remote activation external start wire is a negative input wire too. Could i hook all this up the the same wire if i found it or not? Any suggestions are appriciated.
Not sure of your question....
What Year, Make & Model Vehicle are you installing into??
MO
1995 Mercury Sable GS Station wagon. I found the answer to my first question but now i have another problem. I cut the wire that was suppose to be the wire to my starter so i could put in the starter disable relay. I don't know what the deal is but my car wouldn't crank once i got everything hooked up. SO i unhooked the relay and reconnected the wires and not my car still won't crank. Any suggestion on what to do or what the problem could be?
