programming 3rd key chrysler
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67782
Printed Date: May 09, 2026 at 4:57 PM
Topic: programming 3rd key chrysler
Posted By: dadz
Subject: programming 3rd key chrysler
Date Posted: December 06, 2005 at 8:16 AM
I am installing a remote start in a chrysler with the sentry key. I have the 2 originals and a 3rd key that is cut but not programmed. I can't remember the sequence to prograqm the third key, can anyone help me out.
Thanx
Posted By: Velocity Motors
Date Posted: December 06, 2005 at 8:55 AM
What year Chrysler & model do you have ??
Posted By: dadz
Date Posted: December 06, 2005 at 8:56 AM
2005 Stratus.
Posted By: JWorm
Date Posted: December 06, 2005 at 11:50 AM
Temorarily set the remote start to diesel mode. It should power up the ignition for at least 15 seconds before attempting to crank. If it has a glow plug input wire, temporarily ground it.
Insert key 1 and turn on for 8 seconds.
Insert key 2 and turn on until you hear a chime (about 12-15 seconds)
Insert 3rd unprogrammed key, hit button to remote start car. Ignition will power up. Somewhere in the car the red Sentry key light will begin flashing. After about 12-15 econds it should go on solid for a few seconds. Your key is programmed.
Posted By: dadz
Date Posted: December 06, 2005 at 1:00 PM
Thanx again
