Viper 791vx, starter kill won’t go off
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67935
Printed Date: April 07, 2026 at 11:53 PM
Topic: Viper 791vx, starter kill won’t go off
Posted By: civicintrouble
Subject: Viper 791vx, starter kill won’t go off
Date Posted: December 08, 2005 at 12:37 AM
Hello, guys.
I just installed (well I don't know if this counts) a viper791vx alarm in my 95 civic. It opens and closes the doors and everything else ok, chirps and flashes...but I can't disarm the starter kill. Everytime I hit disarm, the doors open, i hear 4 chirps, the led flashes 3 then 2 then 3 ...., the remote says the doors and shock are going off, and the starter kill is still active. When I arm it again then disarm it keeps doing this. Please help me, I am begging you.
(note that I had the battery disarmed for a while and when I reattached it, the alarm worked fine, but now it does this)
Posted By: jacqueslacombe
Date Posted: December 08, 2005 at 12:49 AM
Hi!  Make sure you did not reverse the ACC and the IGN wire     ACC is yellow          IGN is BLACK / YELLOW
cocolaboy
Date Posted: December 08, 2005 at 1:01 AM
Nah, I got the car started right after I connected the battery. It makes a ticking sound off the starter kill when I try to start it now. I didn't touch any other wire after starting it the first time.
Date Posted: December 08, 2005 at 1:27 AM
ARE you sure you did not a IGN kill instead of a starter kill !
tell me wich color wire of the viper you connect to wich color wire of the honda
cocolaboy
Date Posted: December 08, 2005 at 1:34 AM
Uh, thanks for the help, but how could I start the car the first time if I did that? And why would the alarm go berzerk now? I figure I must have put it into some funny mode or the brain is screwed up. Anyone know what the code for 3...2...3...2 is when I disarm?
Posted By: redpeppers
Date Posted: December 08, 2005 at 1:47 AM
those flashes let u know what zones have been triggered in the alarm brain....like the doors or shock senor or ignition....like jacqueslacombe said if u taged the right ignition wire... then when u turn the key on the flashing lights will go away......sounds like u dont have the right wires.....where did u get ur wire diagram?
Where theres is a wire there's a way.
Date Posted: December 08, 2005 at 2:07 AM
I used the honda factory manual. I might have screwed up though. I will check it tomorrow. The thing is it sends these codes when it is disarmed yet the alarm doesn't go off when it is armed. I'll check it again. Thanks.
Date Posted: December 08, 2005 at 3:30 PM
I interupted the BLK/WHT wire with starter kill and got the ORG going to the YEL. I got the RED and RED / WHT going to the WHT.
Date Posted: December 08, 2005 at 3:32 PM
I still don't know why the thing is giving me the 4 chirps and saying the doors and shock are going off everytime I disarm when it doesn't even sound an alarm. If I try to open the door when it is armed it sounds so the siren works. Please help.
Posted By: cntrylvr79
Date Posted: December 08, 2005 at 5:46 PM
Do you have the pink wire hooked up to anything?  If not that could be why the alarm is doing what it's doing.  Pink should be hooked to BLACK / YELLOW in the car, as if there's a white black in the car hook the pink/white up to that one.  It's the second accy which may not be in that civic I don't remember no diagram for the car in front of me right now.  One  more thing make sure you have the green wire of the starter kill hooked to the key side of the BLACK/ white wire and purple to the other side.   Later
Cause I'm So white and nerdy...
First Class Certi-fried installer
Date Posted: December 09, 2005 at 7:58 AM
HI! make sure you have a good ground that is very important and make sure you do not have any wire mist placed in the viper alarm connector I'va seen that before on a clairion alarm
cocolaboy
Date Posted: January 14, 2006 at 1:53 AM
I just wanted to say thank you for all the people who responded to my plea. What I initially though was the alarm was was build up on the battery terminals. This caused the car to start one moment and not the next. It also caused the alarms sensors to think they were going off when they weren't. I again thank you all for your help.
