Compustar 1WAM4R
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67968
Printed Date: April 07, 2026 at 2:09 AM
Topic: Compustar 1WAM4R
Posted By: ctatty
Subject: Compustar 1WAM4R
Date Posted: December 08, 2005 at 11:58 AM
Hi...I recently got the Compustar remote start installed into my 2005 Ford F-150 Supercrew. The truck starts fine. It's just the manual doesn't say much about the remote start and how to work it. My vehicle runs about 10-15 minutes before it stops when started with the remote start...I was wondering if there's a way to program the remote start to run longer than 10-15 minutes? And is there a way i can reset the run time back to the beginning without shutting my truck off?
Thank you for your help
Posted By: forbidden
Date Posted: December 08, 2005 at 2:53 PM
There is a switch on the inside of the brain for run time. If your brain is the CM4200, dipswitch#2 is the 15 minute (off setting) and 25 minute (on setting).
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: side show bob
Date Posted: December 08, 2005 at 3:53 PM
Same if your control module is CM3000, select dip sw#2 to the 'on' postion. That should give you 25 minutes of run time.
------------- Side Show Bob
Posted By: jdeezay
Date Posted: December 08, 2005 at 7:41 PM
if you want more time than that turn on option 1-8 set the delay for 3 sec. and put dip switch #2 on and that can give you 45 mins if thats long enough
