2004 mazda 3 clutch
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=68036
Printed Date: April 04, 2026 at 12:10 PM
Topic: 2004 mazda 3 clutch
Posted By: 05gt
Subject: 2004 mazda 3 clutch
Date Posted: December 09, 2005 at 2:55 PM
I have a 2004 mazda 3, manual transmission, I have a command start 386IM remote starter for it
this remote start is designed for a manual transmission, I am wondering if anyone can tell me how to bypass the clutch properly on this car, I need to know which pins on the relay go where
Posted By: kohara73
Date Posted: December 09, 2005 at 9:17 PM
Look at the switch where clutch travel bottoms out.  Probably two wires going to it.  You need to connect them permanantly or have the remote starter supply a ground or positive pulse (depending on the car) to the correct wire.  You can find the correct wire by backprobing with your DMM to see witch one is operated by the the switch.  I have a Ford Focus ST which is very similar to your Mazda and the clutch is a ground wire.
Keith
Posted By: 05gt
Date Posted: December 09, 2005 at 10:53 PM
yah but this is different there are two switches both with two wires coming out of them
the bottom switch which you mentioned, both the wires are black with a yellow stripe, and apparently it is triggered from the starter wire, correct me if I am wrong
Posted By: extreme1
Date Posted: December 09, 2005 at 11:29 PM
in the harness coming down the drivers sill. look for a grey/black wire. test to see what it does, last one I did was a negative type clutch, but I've heard there's positive clutch in there too.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: 05gt
Date Posted: December 10, 2005 at 12:00 AM
yah that will be fun, well there is only one harness running down the sill and up the kickpanel, but there is like 6 or 7 grey/black wires in it
I tried hooking the park brake wire from the brain right to the (-)neutral safety wire at the ECM in the engine compartment
but that wouldn't work cause I realized that this is a manual safe unit and I had to do a proper shutdown sequence to remote start which included pulling the park brake, so that wouldn't work
Posted By: 05gt
Date Posted: December 10, 2005 at 12:01 AM
which visions do you work at extreme, I work in british columbia
Posted By: kohara73
Date Posted: December 10, 2005 at 3:12 AM
When you say there are two switches, do you mean one switch at top of clutch pedal travel and one at botom?  If this is the case, the top switch is to turn your cruise off and the bottom switch is for the starter.
Keith
Posted By: extreme1
Date Posted: December 10, 2005 at 8:24 AM
red deer.
call me later (403)309-2770
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: 05gt
Date Posted: December 10, 2005 at 1:33 PM
yah this the way it is, can you tell me how to wire the relay or whatever has to be done please
Thankyou Mike
Posted By: KarTuneMan
Date Posted: December 10, 2005 at 2:19 PM
Use the grey/black It needs a NEG(-) "start " signal. As well as the starter wire at the ign. switch.
Posted By: kohara73
Date Posted: December 10, 2005 at 8:02 PM
Of the two wires on the bottom switch, you say they are both yellow/black.  One is towards the floor and one is kind of above it.  I believe it is the one on top that is switched.  Check for continuity to ground on both.  The bottom wire on the bottom switch is probably grounded at all times, while the top wire on the bottom switch is probably only grounded with the clutch in.  The wire that is only grounded while the clutch is pressed in is the one you want to send a neg. pulse to while cranking.  You could also bypass clutch permanantly by cutting the two and connecting and soldering them.  This will mean you NEVER have to push the clutch in to start the car.
Keith
Posted By: 05gt
Date Posted: December 10, 2005 at 10:52 PM
I know, I would never bypass the clutch that way, I got it to work, from a few previous post, thanks for all the info
Posted By: kohara73
Date Posted: December 11, 2005 at 1:49 PM
bobk]k wrote:
hara73, bad idea to bypass the clutch the way you suggest.
Which way is bad, the permant way??  I know it's bad but it's an easy answer if someone is too lazy to bypass it only during crank...I'm only telling him his options...I'm not SUGGESTING anyhting.
Keith
