Clifford alarm problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=68099
Printed Date: April 02, 2026 at 6:00 PM
Topic: Clifford alarm problem
Posted By: too_funny
Subject: Clifford alarm problem
Date Posted: December 10, 2005 at 7:21 PM
Clifford Model 10 alarm, recently bought from Fry's electronics.
Car: 2000 Honda Prelude, factory prewired for an alarm.
I have everything working except for the doors. I can't get them to lock and unlock.
Here is what the alarm door lock harness look like:
Violet: unlock #87 normally open (input)
Blue/Black: unlock #30 common (output)
BROWN / Black: unlock #87a normally closed
Violet/Black: lock #30 normally open (input)
GREEN/ Black: lock #30 common (output)
WHITE/ Black: lock #87a normally closed
BLACK/ White: domelight supervision relay input #87
I am tapping these wires here:
Arm (key)
20ga. RED / White (-) at factory alarm harness located above foot pedals (should also lock doors)
Disarm (key)
20ga. GREEN/ Orange (-) at same (should also unlock doors)
These instructions were found on this website and was very helpful so far, except now I am stuck on this part of the install.
I have try out the different lock/unlock wires on the alarm but nothing happens when I push the lock/unlock button.  I am out of ideas, am I missing something?
Any help would be great. Thanks.
Posted By: cntrylvr79
Date Posted: December 10, 2005 at 11:12 PM
Violet: unlock #87 normally open (input)  - goes to ground
Blue/Black: unlock #30 common (output) - goes to the GREEN/ orange in the car
BROWN / Black: unlock #87a normally closed - don't need it
Violet/Black: lock #30 normally open (input)  -  goes to ground
GREEN/ Black: lock #30 common (output)  - goes to the RED / white wire in the car
WHITE/ Black: lock #87a normally closed   -  don't need it
BLACK/ White: domelight supervision relay input #87 - if you're doing domelight supervison hook this up to ground other wise don't need it
Cause I'm So white and nerdy...
First Class Certi-fried installer
Date Posted: December 11, 2005 at 2:50 AM
Thanks man, I really appreciate your help. posted_image I didn't know I needed to ground the violet wires.  posted_image
