01 Dodge Ram Airbag light
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=68156
Printed Date: March 20, 2026 at 2:26 AM
Topic: 01 Dodge Ram Airbag light
Posted By: CRjoslin15
Subject: 01 Dodge Ram Airbag light
Date Posted: December 11, 2005 at 5:46 PM
I have installed an excalibur atv-1000 in my 2001 dodge ram 1500.  Everything went ok after everyone in the forum helped me out.
Now i have a problem with the airbag light staying on.  I have tried disconnecting the negative battery wire for 10 minutes, turning the ignition on then pulling the negative battery wire, and checked every fuse that i could find.
I have seen a few things on the forums about reseting lights but not about Rams. Any help would be greatly appreciated.  Basically, the only reason i am even worried about it now is because i am selling the truck and want to make sure it is okay for the next guy.
thanks,
crjoslin
2001 Dodge Ram 1500 V6
Posted By: Teamrf
Date Posted: December 11, 2005 at 7:44 PM
If you put a remote start on there you need to see if you powered all the acc., ang ignition wires. If it has two starters both need to be powered during crank.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Date Posted: December 11, 2005 at 8:21 PM
I haven't put a r/s on it.  The truck is a manual, too risky for me.  How would I find out if the truck has two starters?
I looked at the vehicle wiring charts and it only has one ignition wire.  I, just, noticed that there is a wire for ign key warning. Could that be part of the problem, i.e. it should be tied into the alarm?
Constant 12 voltsRED & PINK/BLACKIGNITION SWITCH HARNESS
Ignition 12 voltsD BLUEIGNITION SWITCH HARNESS SEE TECH
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightYELLOW (-)26 PIN CONNECTOR BEHIND DRIVER DASH
Trunk Pin SwitchN/A
Parking LampBLACK / YELLOW (+)74 PIN CONNECTOR BEHIND DRIVER DASH
Power LockORANGE / VIOLET16 PIN CONNECTOR IN DR.
Power UnlockPINK/VIOLETKICK PANEL
Reversal Rest At Ground Door Locks
Accessories
Window UpD\ L BLUE P\ BROWN / WHITE @ MAIN SWITCH
Window DownR/ WHITE S/ VIOLET/WHITE
Ign Key WarnL BLUE (-)IGNITION SWITCH HARNESS
Trunk ReleaseN/A
OEM HornBLACK/ RED (-)74 PIN CONNECTOR BEHIND DRIVER DASH
HeadlightsL GREEN (-)AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmL GREEN/ ORANGE (-)IN PIN 8 OF A 16 PIN CONN DR.KICK *
Posted By: Hornshockey
Date Posted: December 12, 2005 at 2:58 AM
Generally airbag lights cannot be reset without a trip to the dealer. It's a safety issue so they make sure that you have to have the SRS system acutally looked at; to determine what set the light.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
