508d and a 530t?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=68252
Printed Date: April 29, 2026 at 4:06 PM
Topic: 508d and a 530t?
Posted By: cntrylvr79
Subject: 508d and a 530t?
Date Posted: December 12, 2005 at 9:17 PM
So I was thinking about something the other day and I figured I'd see what y'all thought of my idea.  First things first, I have an 03 Galant with an Audiovox 901 in it.  During the summer I like to leave the windows down to keep the car from getting disgustingly hot.  My only concern is recently I put an avic-d1 in and I don't want it getting jacked.  So I was thinking,  I have 2 530t's in the car want to wire up a 508d so that if someone tries to reach into the car the windows will roll up.  I don't want to wire the 508 directly to the alarm since I've always had issues with neighborhood cats setting the alarm off at 2 am and beleive me you don't want to be anywhere near that car when the horn sirens and airhorns go off.  So anyway here's what I was thinking for wiring it.
508d
Red - Constant +12v
Green - Not used
Blue - to 85 of relay 1
black - to gwa of alarm
Relay 1
85 - blue from motion sensor
86 - constant +12v
87a - gwa from alarm
30 - orange wire of 530t's508d
SO basically when the inner perimeter of the 508 is violated it triggers the relay which disconnects the ground when armed from the window controllers momentarily.  They read that as a command to roll the windows up and my navi is safe from stupid people.
Cause I'm So white and nerdy...
First Class Certi-fried installer
Posted By: auex
Date Posted: December 12, 2005 at 9:57 PM
Well that will all work fine, except all you have to do to stop the window module is grab the window. Also if you do it, make sure the relay is away from the shock sensor.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: December 12, 2005 at 10:01 PM
Yeah I figured that but I'll take what I can get. As for the shock sensor,  the window controllers disable the shock sensor while they're activated
Posted By: auex
Date Posted: December 12, 2005 at 11:13 PM
It will only disable if the alarm is controlling it, which in this case it won't be. The relay can trigger the shock sensor if it is too close. Also you should tie both the green and blue wire to the relay.
