2000 JGC JDL-PK, RS-900 VII
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=68385
Printed Date: April 18, 2026 at 2:07 PM
Topic: 2000 JGC JDL-PK, RS-900 VII
Posted By: remborsk
Subject: 2000 JGC JDL-PK, RS-900 VII
Date Posted: December 14, 2005 at 5:32 PM
Hello I recently purchased a RS-900 VII remote starter and a JDL-PK for installation into a 2000Jeep Grand Cherokee Laredo.  I have a few questions about the install.
1) Does Pin #3 of the RS-900 run to the brown wire on the JDL-PK?
2) Does Pin #4 need to be installed if no trunk pop or Dome Light Illumination is requested?
3) What does Pin #5 (Green) get wired to?
4) Pins #9 & 10. Do these get wired to the vehicles harness or the JDL-PK?
5) On the High-Current connector is it necessary to hook up the parking light output? And am I correct in saying the Pink/White wire is not necessary for my install?
As for the JDL-PK:
1) Brown wire gets wired to Pin #3 on the remote starter?
2) Do the Green, Blue and Violet/White wires get wired to the door module in the drivers door?
Any help is appreciated with my install. Thanks for your help!
Rick
rickemborsky@gmail.com
Posted By: remborsk
Date Posted: December 14, 2005 at 8:14 PM
After doing some extensive searching I found this info to help for anyone else who might be looking!
https://www.the12volt.com/installbay/forum_posts.asp?tid=21865&KW=rs%2D900#reply
