ProStart 5060 will not enter program mode
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=68708
Printed Date: May 14, 2026 at 5:14 PM
Topic: ProStart 5060 will not enter program mode
Posted By: rezbomb
Subject: ProStart 5060 will not enter program mode
Date Posted: December 19, 2005 at 9:02 AM
Hi all, finished installing the 5060 into a '95 Ranger. All wiring has been checked and seems to be correct. When I first tryed to program, it kept going into panic, got the fix from another thread, went into valet, out of valet problem solved. Now when I flash the hood pin, holding it for 4 secs, then releasing, the parking lights come on for 2 secs and go off. Try it again and the same thing. I can't get the module to enter program mode, any ideas?
Posted By: rezbomb
Date Posted: December 19, 2005 at 10:24 AM
ok, called the manufacturer, problem solved just a bit of finger trouble.
Next problem, I'm trying to get into ready mode, engine running, parke brake set, press lock, get my three flashes, turn the key and it shuts down? any thoughts?
Posted By: rezbomb
Date Posted: December 19, 2005 at 2:35 PM
Everything is working, alarm and remote start. In the end turns out it was an intermittant door switch on the drivers door. Switch cleaned and no faults.
