Audi S8 1998 D2 (A8)
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6880
Printed Date: March 31, 2026 at 2:35 AM
Topic: Audi S8 1998 D2 (A8)
Posted By: jaxman
Subject: Audi S8 1998 D2 (A8)
Date Posted: December 19, 2002 at 12:44 PM
Hello again everybody.
Can somebody give me some details about the pre-installed security system in this car ?
Wires for the built in imobilizer , trunk release , and how is the system actually working ?
How it can be disabled in the easyest way or bypassed ?
What kind of imobilizer it is used ?
Thank you in advance.
Damn cold here ...:^:
Posted By: jimmythegreat1
Date Posted: December 20, 2002 at 10:49 PM
Audi
S8
2002
Alarm
Function Color Location
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts BLACK IGNITION SWITCH HARNESS
Starter RED / BLACK IGNITION SWITCH HARNESS
Dome Light BROWN / YELLOW (-) DRIVER'S SIDE OF TRUNK AT PUMP
Trunk Pin Switch RED / BLACK (-) DRIVER'S SIDE OF TRUNK AT PUMP
Parking Lamp GREEN/ RED (+) AT SWITCH HARNESS
Power Lock BROWN / YELLOW DRIVER'S SIDE OF
Power Unlock BROWN / RED TRUNK AT PUMP *
* Requires Two Negative Pulses To Unlock. Information Courtesy Of Installer!!Any Additional Information Appreciated!!
Accessories
Window Up
Window Down
Ign Key Warn
Trunk Release
OEM Horn
Headlights YELLOW (+) AT SWITCH
OEM Alarm Arm
OEM Alarm Disarm
Remote Start
Tach Signal BLACK AT FUEL INJECTOR #239
Ignition #2
Ignition #3
Accessory YELLOW/BLACK IGNITION SWITCH HARNESS
Neutral Safety
Brake Light RED / BLACK (+) AT SWITCH ABOVE PEDAL
Reverse Light BLUE/RED (+) DRIVER'S KICK PANEL
Rear Window Defrost
#239 See Immobilizer Bypass Diagram. Information Courtesy Of Installer!!Any Additional Information Appreciated!!
InterConnect Harness
Function Part # Available Location
StrInt,+12,Gnd,Ign no
Horn Honk no
Lock & Unlock no
Light Flash no
Dome Light no
Trunk Switch no
AL-100 / VIP-4000 no
Remote Start AL100/VIP-4000
RKE Module
Motor Lock
Motor Unlock
Drv Door Unlock
OEM Relays
Addon Security Type
Tech Notes
Driver Passenger Size Location
(+) Front
(+) Rear
Omega disclaims any responsibility or liability in connection with installation. © 2000 Omega Research & Development, Inc. Douglasville, GA 30134 USA
