2002 express chevy custom van
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6886
Printed Date: March 31, 2026 at 2:30 AM
Topic: 2002 express chevy custom van
Posted By: jimmythegreat1
Subject: 2002 express chevy custom van
Date Posted: December 19, 2002 at 3:30 PM
Hey is the wiring for the Express Full size chevy van the same as the astro 2002?
Posted By: 10nesne1
Date Posted: December 19, 2002 at 10:41 PM
YEAR: 2002 MAKE: Chevrolet MODEL: Express Van STYLE:
|       ITEM          |     WIRE COLOR      |POL |       WIRE LOCATION        |
|                 12V |red or RED / white     | +  |ignition harness            |
|             STARTER |yellow               | +  |ignition harness            |
|            IGNITION |pink                 | +  |ignition harness            |
|     SECOND IGNITION |pink/white or white  | +  |ignition harness            |
|           ACCESSORY |orange               | +  |ignition harness            |
|          POWER LOCK |lt. blue             | +  |drivers door harness        |
|        POWER UNLOCK |white                | +  |drivers door harness        |
|          LOCK MOTOR |gray                 |    |drivers kick panel          |
|        UNLOCK MOTOR |tan                  |    |drivers kick panel          |
|       DISARM DEFEAT |tan                  |    |passengers kick panel       |
|    PARKING LIGHTS + |brown                |    |light switch                |
|          HEADLIGHTS |yellow               | +  |light switch                |
|        DOOR TRIGGER |purple               | -  |drivers door harness        |
|     TRUNK/HATCH PIN |ORANGE / black         | -  |at light in rear cargo area |
|          TACHOMETER |white *2             |    |VCM *1                      |
|          BRAKE WIRE |white                | +  |stop light switch           |
|        HORN TRIGGER |black                | -  |above ignition harness      |
|              WIPERS |brown                | +  |steering column             |
|   LF WINDOW UP/DOWN |dk. blue - brown     | A  |LF window motor in door     |
|   RF WINDOW UP/DOWN |lt. blue - tan       | A  |drivers door harness        |
NOTES:NOTE: This vehicle has the passlock II immobilizer system that, whenadding a remote start, must be interfaced with. Use DEI part 555t or 555L.*1 The VCM is located under the hood on the drivers inner fender well.*2 Diesel wait to start wire is dk. blue (-) located at the instrumentcluster 'see direct fax document #1090'.
Date Posted: December 20, 2002 at 10:24 PM
Ok here is the situation. the keyless entry in the van from the factory will unlock the drivers door when pressed once and all of the others when pressed twice. using a prestige 785 plat.. I could use the green wire to lock all the doors on arm, using the RED / black I was able to unlock all of the doors only =. and only when I hit the unlock(disarm) 2 times. using the red wire of the alarm which should disarm the drivers door I got no result. When testing the wire (TAN) as everyone says I got a 12V+. the alarm gives me a 12v+ when I hit disarm. But it will not unlock the door it does nothing. I even went straight to the lock itself with no results? I even swapped the brain out on htis unit to try to resolve this issue, can anyone here help.... I even tryed to 5 wire the lock this just burnt the green lock wire of the alarm, now I have to replace the brain with a third unit.
Posted By: 10nesne1
Date Posted: December 21, 2002 at 12:09 AM
