2001 Maxima Key Sense, Do I Need It?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=69069
Printed Date: March 12, 2026 at 11:50 AM
Topic: 2001 Maxima Key Sense, Do I Need It?
Posted By: Mattthew278
Subject: 2001 Maxima Key Sense, Do I Need It?
Date Posted: December 23, 2005 at 8:39 PM
I bought a bypass off ebay, made by crimestopper, it says it "might" be required to use the yellow key sense wire if the vehicle requires it.  The module has a red and black also.  Anyone know if the Maxima will requires the yellow?  And if so, what wire it is in the car?  Thanks for your help.
Posted By: mo12v
Date Posted: December 23, 2005 at 8:58 PM
I don't use it........
Depends on application:
Ign Key WarnBLACK/ RED (+)AT SMART ENTRANCE CONTROL UNIT *
* "Smart Entrance Control Unit" Located Right Of Steering Column Behind Driver Dash
MO
Date Posted: December 23, 2005 at 9:23 PM
Thanks for the quick reply....It also says a diode might be required for the yellow wire....would this just depend on whether the key sense was positive or negative?  Should I use one in this case?  Thanks again
Posted By: mobile1
Date Posted: December 23, 2005 at 9:54 PM
you shouldn't need it on this car. what it does when you hook it up to  the bypass mod, is shut off the bypass when a key is inserted. some vehicles can't see two keys at the same time.
