996a RS for 05 grand cherokee
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=69169
Printed Date: March 14, 2026 at 3:04 PM
Topic: 996a RS for 05 grand cherokee
Posted By: birdmanak
Subject: 996a RS for 05 grand cherokee
Date Posted: December 25, 2005 at 7:51 PM
Hey all, new member here. My wife got me an Audiovox 996a RS for christmas. I will be installing it in our 05 grand cherokee. From the little bit of reading I have done so far I can tell I need to get some other stuff than what was included in the box. I would like to get everything in hand before I start the install of this. What all extra do I need to get? Are there any other good website for installation tips? Thanks in advance for any help/information you can provide.
Posted By: OhioMike1101
Date Posted: December 27, 2005 at 6:42 AM
Unless you are familiar with relays, polarity changes, making good connections, how to use a DMM, etc.... I would leave it to the pros.
Date Posted: December 27, 2005 at 2:58 PM
Well I have a degree in EE, so I have messed around with plenty of electronics, I have done all the work on my other jeep (TJ) from installing the sterio to swapping out the axle. This remote start is a little more complicated of an install I would say, but I dont think it is out of my range. Just looking for a little help is all. The shops here in Alaska wanted anywhere from 600 bucks to 800 bucks to install a 2 way RS. So I am just trying to get all my ducks lined up before I tear into the car. I have searched this forum and have found some info like the wiring diagram. From what I have found so far I need a relay to work the door locks, and some sort of bypass module. So far I have only been able to find the generic ones that you put a spare key in for an 05 Grand Cherokee. Again any help would be greatly appricated.
Posted By: Mike M2
Date Posted: December 27, 2005 at 5:34 PM
Certainly not an easy install on that car. You will need 2 relays and 2 resistors, 150 and 560 ohm, for the ignition switch interface. The locks will need a pair of relays and 2 resistors, 100 and 330 ohm. You cannot use the parking lights at all on this car, instaead you must use the hazards but is a direct negative pulse(no relay needed). If you need door triggers, they are all independant and would need to be diode isolated. A556C will work, but i prefer using a 556u and losing a key, more reliable IMHO.
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: Chris Luongo
Date Posted: December 27, 2005 at 10:32 PM
HI, Audiovox installer here, and I've done a few Grand Cherokees too.
--The negative park lights can be had by tapping into the correct terminal, at the correct relay in the underhood fusebox, but I have never gone to that much trouble. (Same goes for the horn----that relay is under there too.)
--Go to the www.carsound.com forums and do a search on the Chrysler 300 or 300C. I believe my method of dealing with the resistor-based ignition wire is best.........with the other diagrams around, when you switch the key on after remote starting, the car's radio and climate controls go dead until after you hit the brake and kill the remote starter----harmless but annoying.
--You can probably just use the car's domelight wire as the door trigger, instead of diode-isolating the individual pinswitches------but you mustn't disable the domelight with the control on the turn signal lever, or then the alarm wouldn't go off if someone broke in.
--Go to bypasskit.com and see if they sell a piece that might make it easier to do the doorlocks. Even if they don't, I've rarely needed relays to do locks on a Chrysler product-----connect a pair of diodes (to block the positive pulses from the Audiovox unit) and fiddle around with different resistors until it works. (The wrong resistance won't blow anything up.)
--As far as dealing with the transponder in your key, you have a few choices:
A: Buy a universal key-in-the-box module like a DEI 555U or 556U, Audiovox AS-TCBM, or bypasskit.com TBK-III. You'll permanently LOSE one of the two keys that came with your Jeep----it goes inside the bypass box.
B. Get a DEI 556C or bypasskit.com PKU-CH2. It is basically a bypass box with a Chrysler transonder chip already inside------you program the chip to the car, and KEEP both your keys.
C. Get a universal key-in-the-box module, AND buy the correct blank Chrysler key from www.howardkeys.com, www.hlflake.com, or eBay. Plant the blank key in the box------you are doing the same thing as "B" above, except you're making it yourself out of two different pieces------as a pro, my cost is cheaper if I do it this way.
D: BEST CHOICE (in my opinion) Now that the 996A will be controlling everything, the factory Jeep remote control is just a nuisance......if you unlock the doors with it by mistake, it'll set the aftermarket alarm off.
If it were my car, I'd get a regular Chrysler key and program it to the car------whether you go do the dealer or a locksmith, or buy your own keyblank on eBay, pay a locksmith to cut it, and program it yourself. (Programming is easy; instructions are in your owner's manual.)
Now you have two of the factory Jeep remotes, and one plain key.
Plant the remote from one Jeep key in the bypass box and forget about it. Make the other Jeep key your spare. Attach the gray Chrsyler key to the Audiovox remote, and carry that around.
Date Posted: December 29, 2005 at 10:11 AM
Thanks for the help guys. Are the relays used in this application a special relay? or will a standard 30amp type relay work?
Posted By: Mike M2
Date Posted: December 29, 2005 at 4:25 PM
I have done the parking light trick before on Ram pickups, it does work fine. Yes, standard 30a relays will work. A 451M from DEI would make the locks easier....
Tech Manager
CS Dealer Services
