556U loop
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=69289
Printed Date: May 09, 2026 at 10:18 AM
Topic: 556U loop
Posted By: mugpar
Subject: 556U loop
Date Posted: December 27, 2005 at 10:25 AM
I broke the loop on a 556U any idea where I can get a new one, without having to by a whole new bypass? Or can i make one? Thanks
Posted By: Mike M2
Date Posted: December 27, 2005 at 5:38 PM
You can make one, it's a little tedious. Strip a piece of wire about 4 feet long and pull out two strands. Wrap them around an empty toilet paper roll and connect each end to the black ribbon cable. crush the paper roll and remove the coil, then lightly twist it to make it stay together.
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: OhioMike1101
Date Posted: December 27, 2005 at 8:45 PM
I say just go buy a new 556u..... seems alot less work.
Posted By: Ween
Date Posted: December 27, 2005 at 9:58 PM
hi, shouldn't the turns of wire be insulated (i.e. insulated instead of bare wire)? bosch type relay lying around? still use the toilet paper roll as a form, but add a turn of electrical tape inside out to hold the wire in place as you wrap around it. just my two cents mark
Posted By: Mike M2
Date Posted: December 28, 2005 at 6:43 AM
The looped wire on the 556U loop isn't needed. I cut that off on every Toyota i do just so the shroud fits better. You gotta be carfull not to knick a wire tho. I always make sure the loop is on plastic, so letting it touch chassis ground may make it not work. ------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: mugpar
Date Posted: December 28, 2005 at 2:41 PM
Don't I need the loop on a chrysler 300c? I hear they are a real pain to get the loop to even site right.
Posted By: Mike M2
Date Posted: December 28, 2005 at 2:44 PM
Sorry, a typo!!!!! I meant the looped plastic around the coil isn't needed....  ------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: mugpar
Date Posted: December 28, 2005 at 11:10 PM
Well the whole coil broke off, it came off right before the loop starts, so can i just put the loop back together with the wire?
Posted By: Mike M2
Date Posted: December 29, 2005 at 6:26 AM
Eevn one small strand being broken will make it not work. If your that good to get it together and have zero breaks, your gold...
Tech Manager
CS Dealer Services
