Cruise Failure after RS Install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=69379
Printed Date: May 07, 2026 at 4:15 PM
Topic: Cruise Failure after RS Install
Posted By: Simplemitch
Subject: Cruise Failure after RS Install
Date Posted: December 28, 2005 at 11:09 AM
I put a Remote start into a 2002 Chevy Trailblazer and everything seems to work, but the customer says that the cruise control doesn't work now. I had them bring it back in to check for loose harnesses and so forth, but the only thing I found to be out of the ordinary was that the column shroud was missing the screws that hold it together (and I never took it off). Gave vehicle back to customer to try again and they said that the cruise worked twice and then quit working again. Everything else on the shaft works (washer fluid, wipers, blinkers), just not the cruise. I asked if they were sure they understood how to operate it and to make sure they were engaging it over 25 mph, etc.... they said they've used it a million times before.
What gives?   Any ideas?
Mitchell Whitney, Installer/technician
Mainstreet A/V
Posted By: kgerry
Date Posted: December 28, 2005 at 11:50 AM
try diode isolating the brake wire from the RS........
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: sparkie
Date Posted: December 28, 2005 at 4:55 PM
Check the brake switch. It may have been moved and needs re-adjusting if you inadvertenally moved it. Also check to see if the 4 pin plug off the signal lever for the cruise wiring is plugged together completely. The correct wire for the remote starter to hook into the brake circuit is the thick white wire at the trailer module. The module is clipped to the panel underneath the driver's side dash. It is the thicker of the two white wires there.
sparky
Date Posted: December 29, 2005 at 9:58 AM
thanks guys. I'll try these suggestions.
Mainstreet A/V
