94 f150 door locks/parking lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=69581
Printed Date: April 29, 2026 at 12:06 AM
Topic: 94 f150 door locks/parking lights
Posted By: northern
Subject: 94 f150 door locks/parking lights
Date Posted: December 30, 2005 at 2:23 PM
Trying to find the door locks, i understand there reversal. I found them in the boot, but I tried to follow where they go with no luck.
The parking light I know is at the switch, I can't pop the head light switch off, i tried to pry it a little, then i tried to take the shroud off, but the shroud is being held on by something else, seems like it will break.
Any tips on the door locks would be good.
Posted By: KarTuneMan
Date Posted: December 30, 2005 at 3:11 PM
you might find the lock wires in the pass kick....
Posted By: northern
Date Posted: December 30, 2005 at 5:12 PM
Went through the door boot for the locks.
Now my only problem is the parking lights... I tried to pull the dash off, but the button on the end of the head light switch won't allow access to the back of the switch
Posted By: Scott35
Date Posted: December 30, 2005 at 5:17 PM
You'll have to reach up on the backside of the dash, at the headlight switch, there is a pin you have to press, to release the headlight knob.
Tacomacrew
Posted By: seracis
Date Posted: December 30, 2005 at 6:15 PM
it's not a pin, it's the clip that's in the knob.  It grips the rod.  Find the notch at the back of the knob.  Use a hook tool to pull on the clip.
