Omega AU-84T Magnetic Shock Sensor
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=69590
Printed Date: April 28, 2026 at 4:25 PM
Topic: Omega AU-84T Magnetic Shock Sensor
Posted By: mmh1
Subject: Omega AU-84T Magnetic Shock Sensor
Date Posted: December 30, 2005 at 4:51 PM
Hi,
I have an AU-84T Magnetic Shock Sensor, I think its manufactured by Omega.
It has 1 adjustment dial on the side and 4 wires coming from the unit: red, black, blue, green.
If anyone is familiar with Omega products could you tell me if this is a single or dual zone shock sensor?
Also as it is being hard wired to an alarm with no onboard sensor port, could some one tell me what each of the coloured wires are for.
Thanks, Mo
Posted By: mmh1
Date Posted: January 02, 2006 at 5:14 PM
Has anyone got any ideas on this???
Posted By: desh187
Date Posted: January 02, 2006 at 9:15 PM
this is a 2 stage shock sensor.(zone 1& 2)
red=constant 12 volt,black=constant ground,
blue=alarm(hard)trigger
green=prewarn(soft)trigger
Posted By: mmh1
Date Posted: January 03, 2006 at 3:54 AM
Hi,
Thanks for the wire colours and use.
It only has one adjusting dial, does anyone know how the 2 zone shock sensor works in this case?
Thanks, Mo
Posted By: mmh1
Date Posted: January 03, 2006 at 3:17 PM
Any takers for my query?
If a 2 zone shock sensor only has 1 dial on it for adjustment and a 4 wire harness.
How does it work e.g. how would it decipher a light impact to a heavy impact as there is only one adjustment?
Thanks,
Mo
