2003 Chevy Avalanche, RS 720
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=69724
Printed Date: April 24, 2026 at 5:34 AM
Topic: 2003 Chevy Avalanche, RS 720
Posted By: dionnfr
Subject: 2003 Chevy Avalanche, RS 720
Date Posted: January 01, 2006 at 8:43 AM
I had an Autopage RS 720LCD installed in my Chevy Avalanche.  They installed the GM Data All bypass module.  The problem that I have is that when I shut off the truck, the dorr locks unlock and immediately lock, forcing me to unlock manually.
I have also read that this bypass modue was replaced by the GM SL is this true.
What bypass modules is everyone using for GM vehicles.
Please help.
Posted By: OhioMike1101
Date Posted: January 01, 2006 at 9:38 AM
gmdlbp from bypasskits is what we use
South Side Audio
2501 S. High St
Columbus, OH 43207
Posted By: mobileworks
Date Posted: January 01, 2006 at 7:39 PM
personally love the gmdlbp
Posted By: dionnfr
Date Posted: January 02, 2006 at 8:52 AM
Can anybody help me in getting the wiring information for a 2003 Chevy Avalanche, I have installed a RS 720 and I'm having problems with the door locks.  (When I shut off the car the door locks recycle very fast, open and lock immediately) I have installed the GM data all bypass, thinking of replacing with eith the GMDL-BP or the 457 GW)  I would like o have it as close to factory as I can.  I don't want to lock my self out by leaving the keys in the ignition.
Posted By: Mike M2
Date Posted: January 02, 2006 at 9:14 AM
I like the 457G, works great. Before you change, try redoing your connections. These mods are very touchy when it comes to a good solid ground. That was an issue with the 457g when it was first developed....
Mike M2
Tech Manager
CS Dealer Services
Posted By: dionnfr
Date Posted: January 02, 2006 at 9:38 AM
Thanks Mike,
Just wondering can you help with the wiring diagram with this vehicle.
Posted By: Mike M2
Date Posted: January 02, 2006 at 3:39 PM
12volts red & RED / white  +  ignition harness
Starter yellow  +  ignition harness
Second Starter N/A
Ignition pink  +  ignition harness
Second Ignition white  +  ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition N/A
Accessory orange  +  ignition harness
Second Accessory brown  +  ignition harness
Keysense lt. green  -  ignition harness
Power Lock use 457G or 456G module
Notes: If Directed module 457G or 456G is not available, refer to DirectFax document 1601.
Power Unlock see power lock
Lock Motor gray    driver door module in door
Unlock Motor tan    driver door module in door
Parking Lights+ brown  +  driver kick panel
Parking Lights- gray/black  -  switch or BCM, brown plug, pin B2
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Hazards white  -  steering column
Turn Signal(L) green  +  steering column
Turn Signal(R) lt. green  +  steering column
Reverse Light lt. green  +  BCM, black plug, pin F
Door Trigger see notes  -  see notes
Notes: The driver door trigger is gray/black at the driver door module in the door. The RF door trigger is BLACK/ white at the passenger door module in the door. The LR door trigger is lt. blue/black, pin A3, and the RR is lt. GREEN/ black, pin A2, they are in the purple plug at the BCM. Use all four wires and diode isolate each.
Dome Supervision gray/black  +  BCM, black plug, pin E
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm lt. green  -  driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white  ac  instrument cluster or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10.
For tach can also go to any of the ignition coils or injectors and use the wire that is NOT pink, black, or brown.
Wait to start N/A
Brake Wire white  +  brake pedal switch
Parking Brake lt. blue  -  switch or BCM, lt. blu plug, pin A7
Horn Trigger BLACK / YELLOW to black  -  column or BCM, gray plug, pin B9
Memory Seat 1 red  +  driver door module in door
Memory Seat 2 pink  +  driver door module in door
Memory Seat 3 N/A  +
posted_image
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Passlock II
Part #: 556LW
Alternate Part1 #: 555LW
Alternate Part2 #: 555T
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes: Not required if using the combo interface module.
The Passlock II wire colors are yellow, black (org/blk), and RED / white (not used).
Door Lock Interface
Required:
Yes
Type:
Data Bus
Part #: 456G
Combo Interface
Required:
Yes
Type:
Data Bus
Part #: 457GW
Mike M2
Tech Manager
CS Dealer Services
Posted By: sparkie
Date Posted: January 02, 2006 at 4:13 PM
The problem may not be with your bypass but maybe the remote starter's programming. Most modules are designed to shut off the retained accessory power and rearm the factory alarm after shut down. The GMDAA module does this as well as the GMDLBP module.
sparky
Posted By: uffdog
Date Posted: January 02, 2006 at 6:05 PM
The Gmdl-bp  needs to be set up so it leaves the doors unlocked on shutoff , look at position two on the bypass instructions, I used a gmdl-bp on my Trailblazer and it did the same thing ,locking the doors , I set it to #2 leaves the doors open on shut off and I lock it with the remote now
RFD
