Commando ez2500 problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=69768
Printed Date: April 22, 2026 at 8:50 PM
Topic: Commando ez2500 problem
Posted By: lakechub
Subject: Commando ez2500 problem
Date Posted: January 01, 2006 at 5:37 PM
I have all the minimum  wiring hooked up for the remote start to work on '97 Oldsmobile sihlouette.  I programmed my remotes and set the tach setup for engine not checking(did not hook up tach wire).  I can get horn to work and parking lights to work when programming.  I press car locator button and horn works but when I try to start the car,  the parking lights come on but car does not start.  I can hear relays in control box but I get no voltage at ignition wire 1 or 2.   could it think the car is in gear?  The hood switch is not grounded and brake light circuit is 0 volts.  I am stumped.  I would appreciate any help.  I have about 8 hrs invested
Mark
Posted By: uffdog
Date Posted: January 01, 2006 at 6:56 PM
  Recheck your wiring ,does this car require you to bypass a security key  ie  passlock,vats etc????
RFD
Posted By: lakechub
Date Posted: January 01, 2006 at 7:22 PM
I looked in the manual for this car and I don't see any of  those security features.
What wires do you think I should check?  It must be an input wire of some kind since I don't get any voltage output to the ignition wires.  all 3 red wires are hot going into the unit.  My auxiliary is hooked up correctly.
thanks for the response
mark
Posted By: uffdog
Date Posted: January 01, 2006 at 7:33 PM
1997 Oldsmobile Silhouette Security Information
Constant 12V+Red or RED / White Ignition Switch Harness
StarterYellow Ignition Switch Harness
IgnitionPink Ignition Switch Harness
Ignition 2White Ignition Switch Harness (Instrument Cluster)
AccessoryOrange Ignition Switch Harness (Heat/AC)
TachWhite Harness left Side of Engine
Brake SwitchWhite Brake Switch
Trunk ReleaseGray/Black (-)
Trunk PinGray/Black(-) Same as Dome Light
Parking LightsBrown (+) Firewall Connector
Head LampYellow Light Switch
Factory DisarmPink (-) Switch on DashBoard
Door TriggerPurple (-) Light Switch
Door LockLight Blue (-) Driver's Kick Panel
Door UnlockWhite (-) 10 Pin Connector
Horn WireBlack (-) Steering Column
Windows UpLF=Dark Blue, RF=Light Blue
Windows DownLF=Brown, RF=Tan
I think you also have a security concern since you are not getting power to the remote start, you may want to double check make sure there is  not a passlock sys on this vehicle
RFD
Posted By: lakechub
Date Posted: January 01, 2006 at 8:06 PM
I will double check for passlock type system now.
One other symptom I forgot to mention earlier.  When you press the car locator button on the transmitter I should get 6 chirps from the horn and 12 parking light flashes.  When I do it I get only one of each and this is not programmable.
Posted By: lakechub
Date Posted: January 02, 2006 at 12:29 PM
RFD,  thanks for the help.  I had a weak ground.  I reattached it permanently and everything worked.  I still did not have to hook up the tach wire.
I like to judge the quality of a product by the manual that is provided with it and the commando manual is poor.  I would not purchase this product again.  I ended up getting wiring diagrams from th DEI site because GNU never responded to my requests.
thanks again.  mark
How do I turn these E-Mail notifications off?
