Ultra start 4500, 2005 honda crv
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=69848
Printed Date: April 19, 2026 at 7:32 AM
Topic: Ultra start 4500, 2005 honda crv
Posted By: wscovil
Subject: Ultra start 4500, 2005 honda crv
Date Posted: January 02, 2006 at 2:19 PM
I just Installed an Ultra start 4500 Im having a problem getting it to work ..The parking lights keep blinking and the horn keeps going off. parking lights stay on when the car is running too! it's a 2005 honda crv ...anybody have any ideas"
Wayne
Posted By: gus1
Date Posted: January 02, 2006 at 4:20 PM
Did you do door locks?
Gus
Posted By: wscovil
Date Posted: January 02, 2006 at 5:17 PM
No i didnt do the door locks ..The only other thing that i can think of ,is maybe i didnt get the tach wire on the right spot
Wayne
Posted By: gus1
Date Posted: January 02, 2006 at 5:29 PM
Do the door locks. Car arms with lock, disarms with unlock. Locks are over on the passenger's side, top of the fusebox. Test using the passenger's switch. Make the starter unlock before crank, lock after.
As far as tach goes... there will be a blue wire on a connector taped to a harness on the driver's side of the engine compartment. That is your tach wire.
The parking lights should come on with remote start and stay on if you hooked them up.
Gus
Posted By: wscovil
Date Posted: January 02, 2006 at 6:01 PM
Do you know if i'll have to use relays? also when i start the car with the key the parking lights stay on ,Is this normal?
Thanks for the help
Wayne
Posted By: gus1
Date Posted: January 02, 2006 at 9:26 PM
Shouldn't need relays. They are negative trigger, most alarms out there have negative door lock outputs.
Did the parklights come on before the remote starter was installed?
Gus
Posted By: wscovil
Date Posted: January 03, 2006 at 2:58 PM
I hooked up the locks and it still doesnt work ..The parking lights just keep flashing and the two leds  on the antenna keep flashing until i start the car . Then they stay solid but the parking lights still flash ..any ideas??
thanks for the help
Wayne
Wayne
Posted By: gus1
Date Posted: January 03, 2006 at 3:30 PM
Hit unlock on the remote? Perhaps the alarm is auto arming...
Gus
Posted By: wscovil
Date Posted: January 03, 2006 at 3:54 PM
Gus,any button that push on the remote ,And all that happens is the little key icon flashes on the remote.The doors dont lock or unlock or any thing ...Maybe i got a defect unit??..been trying to get in touch with tech support but no such luck yet ..
Wayne
Posted By: gus1
Date Posted: January 03, 2006 at 4:17 PM
The parklights wouldn't happen to be flashing 7 times, would they? Sounds like the unit is in service mode (been about 3 years since the last Ultrastart pice that I have done)
Gus
Posted By: wscovil
Date Posted: January 03, 2006 at 5:23 PM
Gus,When i hook the battery up.The parking lights blink  30 times ....And like isaid ..the remote does nothing!
This is what i hooked up
starter output
acc output
2 12 Volt inputs
Ign. output
Brake Lite +
Tach
Park Light-
Temp sensor
siren out.
door locks
although the unit has an alarm,Im not going use it ...so as far as i can tell i have all the wires hooked ..also the car has No Factory alarm in it
Wayne
Posted By: gus1
Date Posted: January 03, 2006 at 5:43 PM
Using the programming switch on the antenna, disarm the system. From the sounds of it, it came out of the box with no transmitter programmed, and armed. Nice.
You will need to disarm it using the valet switch, make sure it isn't in valet mode, then program the remote to it.
Gus
Posted By: wscovil
Date Posted: January 03, 2006 at 6:07 PM
Hey Gus that was it!!
Thank you so for all your help!
Very much aprreciated!!
Wayne
Wayne
Posted By: gus1
Date Posted: January 03, 2006 at 8:58 PM
No problem.... I drink Coors Light....
Gus
posted_image
