00 buick wont remote start when cold
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=69940
Printed Date: April 19, 2026 at 4:43 PM
Topic: 00 buick wont remote start when cold
Posted By: sickkindaheadd
Subject: 00 buick wont remote start when cold
Date Posted: January 03, 2006 at 2:10 PM
i have a 2000 buick regal, that wont start when the weather is colder it just cranks but wont turn over......what cold this be? btw it'll start right up with the key....do i need an extra relay on the starter wire maybe it needs more juice? or just another wire that needs 12v when the car is cold to start
Posted By: sparkie
Date Posted: January 03, 2006 at 2:43 PM
Try reprogramming the tach setting when the car is cold. Check all connections especially the ground that they are good. Check the battrey terminals that they are clean and tight. Fix the battery ground cable to the body. The cable end usually makes a poor connection to the body due to corrosion.
sparky
Posted By: thepencil
Date Posted: January 03, 2006 at 2:48 PM
Power up your 2nd ignition wire.
|        IGNITION|pink               |+ |ignition harness            |
| SECOND IGNITION|white or green      |+ |ignition harness            |
Be careful whose advice you buy, but be patient with those who supply it.posted_image
