AX901 not starting on 96 Ram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70326
Printed Date: May 13, 2026 at 1:31 PM
Topic: AX901 not starting on 96 Ram
Posted By: 97f150ext
Subject: AX901 not starting on 96 Ram
Date Posted: January 08, 2006 at 12:33 PM
I installed this system this morning on a 1996 Dodge Ram. After programming the system and learning tach, I tried to remote start and got nothing. The keyless and alarm functions work fine. The unit claimed to learn the tach as the parking lights stayed constant after programming and the safety control switch is installed and turned to "on". This is the first Audiovox remote start system I have installed as I usually only work with DEI. Is there anything I could be missing or need to re-program? Thanks.
Date Posted: January 08, 2006 at 12:54 PM
guess I can answer my own question, after posting I went back to the truck and reprogrammed the unit using the Audiovox programmer I have and everything worked fine. odd since I programmed it once before, but hey whatever works.
