Blackwidow alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70690
Printed Date: April 25, 2026 at 6:56 AM
Topic: Blackwidow alarm
Posted By: vibe03
Subject: Blackwidow alarm
Date Posted: January 13, 2006 at 4:13 PM
I am curious if it is a common practice to connect an alarm to a PCM?  My PCM just got replaced and the mechanic said he noticed the alarm was connected to the PCM and this might have made it go bad.  I have had the same alarm since I got the car.  I was thinking when an auto parts store reverse polarized my battery (september 2005) and smoked my alternator and many fuses it cooked my PCM just enough to let it work for a short time.  Then there is the aftermarket 180 amp alternator?  I have a 2003 pontiac vibe (just incase you didn't catch it in the screen name) and a black widow alarm.
ART
Posted By: mo12v
Date Posted: January 13, 2006 at 5:44 PM
It probably wouldn't matter if the Alarm was connected at the PCM, BCM or the Factory wires in another location on the Vehicle...........
I have come to the conclusion that, when a mechanic sees anything that is NOT Factory, the fault will start there.
Black Widow, ( although I do NOT sell thier products ) is a Good to Medium Line...............Unless there was a obvious miswiring or the Unit is Faulty, I would cast some doubt in what the mechanic said
MO
Posted By: vibe03
Date Posted: January 13, 2006 at 5:49 PM
Thanks for the input.  I was thinking that sounded crazy cause the alarm has been there since I got the car.  I am thinking more and more that the auto parts store messed it up when they reversed polarized my battery.
ART
Posted By: Powermyster
Date Posted: January 14, 2006 at 1:56 PM
yes they would have messed it up in the long term. i wor k for a car dealership and what mo says is right.. as soon as mechanic see's extra wiring in a car they are working on that has an aukward fault. they see it as there scape goat to either get the car out of the workshop or to get the job done outside warranty
Why oh Why didn't i take the blue pill
Darren Power
