04 Ford Ranger-wont start w/key
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70707
Printed Date: April 25, 2026 at 6:18 PM
Topic: 04 Ford Ranger-wont start w/key
Posted By: USMC Vet
Subject: 04 Ford Ranger-wont start w/key
Date Posted: January 13, 2006 at 8:10 PM
Installing a 561R on a 2004 Ford Ranger.I unhooked the ignition harness,the part with the bolt that holds it in.Spliced my wires in and plugged it back in and nothing,I just plugged it back in to check for a constant and nothing with key.What could be the problem?Thanks!
Posted By: mo12v
Date Posted: January 13, 2006 at 8:49 PM
Do you still have voltage to the YELLOW wires in the Plug?
If so....check to see if you bent the connectors
If NOT.....Check your Fuses under hood
MO
Posted By: USMC Vet
Date Posted: January 13, 2006 at 8:57 PM
No power at the yellow constant wires,fuse under hood look good.
Posted By: mo12v
Date Posted: January 13, 2006 at 9:06 PM
Should be a couple of major fuses for Constant Power.
I don't think Ford used Fuseable Links off Battery
MO
Posted By: USMC Vet
Date Posted: January 13, 2006 at 9:10 PM
I found one 40 amp fuse blown under hood,what made it blow?Are you in Iraq?Thanks!
Posted By: mo12v
Date Posted: January 13, 2006 at 9:15 PM
That's the one.........
Be sure not to GROUND or accientally Ground those wires........
Serious problems can occur
Have you got the Wiring Guide for that vehicle?
MO
Posted By: USMC Vet
Date Posted: January 13, 2006 at 9:17 PM
I got the wiring diagram,all I have is a 30 amp,parts store dont open til in the morning,would the 30 work?
Posted By: mo12v
Date Posted: January 13, 2006 at 9:20 PM
It would get you wired............But I wouldn't want to Drive the Vehicle until the proper fuse is in..........It really depends on the load.  Like what is powered thru that fuse
MO
Posted By: USMC Vet
Date Posted: January 13, 2006 at 9:23 PM
Ok,Il go ahead and wire the rest up.I ll get another 40 in the am.Thanks!
