Reservation mode compustar
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70775
Printed Date: April 27, 2026 at 11:35 AM
Topic: Reservation mode compustar
Posted By: muststart
Subject: Reservation mode compustar
Date Posted: January 14, 2006 at 3:59 PM
Having trouble getting into reservation mode. I go through all the steps in order but when I go to remove the key the engine shuts down. Only error code is 7 not in reservation mode.
2000 tacoma 4cly 5 speed  compustar 1wam
Posted By: forbidden
Date Posted: January 14, 2006 at 5:04 PM
Did you accidentally cut the wire loop in the brain? or was it cut already? You verified with a meter that the e-brake wire and the brake wire were giving the proper signal?
Date Posted: January 14, 2006 at 5:44 PM
Loop is intact, never touched. Suspect e brake. Foot brake checks out.
How to test E brake?
Date Posted: January 14, 2006 at 6:00 PM
Thank you, I will try again tomorrow. Have to get ready for Pats game. THANKS again.
