3000GT 93
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7090
Printed Date: March 30, 2026 at 9:14 PM
Topic: 3000GT 93
Posted By: tuceglenn
Subject: 3000GT 93
Date Posted: December 24, 2002 at 9:55 AM
Im wiring my 3000 and I found all of the wires i need except for the ingnition2. the diagram on this site tells me it blue/black but i dont see that color coming from my starter harness. any help is greatly apreciated.
Andrew Tucciarone
Posted By: Velocity Motors
Date Posted: December 24, 2002 at 9:35 PM
That what I have too, here is what I have for the diagram:
|              12V|black or white      |+  |ignition harness            |
|          STARTER|BLACK / YELLOW        |+  |ignition harness            |
|         IGNITION|BLACK/ white         |+  |ignition harness            |
|  SECOND IGNITION|blue/black          |+  |ignition harness            |
|        ACCESSORY|blue                |+  |ignition harness            |
|       POWER LOCK|brn/blu or brn/wht  |-  |high on firewall by DKP     |
|     POWER UNLOCK|brown or brn/blu    |-  |high on firewall by DKP     |
| PARKING LIGHTS +|GREEN / WHITE         |   |white molex left kick       |
| PARKING LIGHTS -|green or grn/blk    |   |left of column              |
|       HEADLIGHTS|RED / yellow *2       |-  |left of column              |
|     DOOR TRIGGER|RED / GREEN/ sil dots |-  |left of column              |
|  TRUNK/HATCH PIN|RED / green *1        |-  |sw. or light in trunk       |
|         HOOD PIN|blue/black          |-  |ETACS mod. under dash *5    |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|lt. green *3        |-  |ETACS mod. under dash *5    |
|       TACHOMETER|white               |   |instrument cluster *4       |
|      SPEED SENSE|yellow/white        |   |instrument cluster *4       |
|       BRAKE WIRE|green               |+  |at switch                   |
|     HORN TRIGGER|GREEN/ black         |-  |steering column             |
|           WIPERS|blu/org, blu/blk    |+  |steering column             |
|  LF WINDOW UP/DN|grn/red - grn/blk   |A  |in drivers door             |
|  RF WINDOW UP/DN|brn/yel - grn/yel   |A  |in drivers door or dkp      |
Notes:
*1 Also blue/white at ETACS if car has anti-theft  *2 Must power the negative park light wire to get the headlights to work.  For pop-up, interrupt blue/red wire at pop-up switch and connect switch side to blue / YELLOW at pop-up switch to raise lights.  *3 must be relay isolated from the door key cylinder  *4 Also found at ECM behind center console. On SOHC models can also use WHITE/ black at the ignition coil for tach.  *5 The ETACS module is located left of the steering column close to the drivers kick. It is flat with its edges facing up, down, front, and back, with its two(2) plugs on the bottom edge.
Date Posted: December 24, 2002 at 10:17 PM
thanks i found everything i needed and its wired correctly now.
Andrew
Date Posted: December 24, 2002 at 10:47 PM
Good to hear... have a good holiday season !!
