’04 Toyota 4-runner, Viper 160xv, rear window
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71032
Printed Date: April 07, 2026 at 7:09 AM
Topic: ’04 Toyota 4-runner, Viper 160xv, rear window
Posted By: curtis.moreland
Subject: ’04 Toyota 4-runner, Viper 160xv, rear window
Date Posted: January 18, 2006 at 10:04 AM
I am putting in a Viper 160xv and the lady wants the acessory on the remote to work the rear window. Now if it was a pop up, no prob. but it rolls down. Can it be done without the 530t module? If so, what are the wires I need to use. I figured since the remote she has controls it, it has to have someting at the Body ECU I could get into to accomplish this without all the time wiring in this module. Any ideas and wiring schematic would be greatly appreciated....
Curtis
It's Fun Ignoring The World !!!
Posted By: Mike M2
Date Posted: January 18, 2006 at 2:42 PM
Here's how i do them, you need just 1 relay. First wire the relay so it gives 12V to the window down switch next to the radio using the RED / white channel 2 off the alarm. Test it with the key on, as it needs igntion on to work. Next you need to tap into the RED / white and have it energize the satelite relay pink/white, so that when Channel two is activated it flips both the relay for the 2nd ignition and the relay energizing the window switch at the same time. Works fine, done tons this way and it's easy after the first one...
Mike M2
Tech Manager
CS Dealer Services
