91 Regal, Remote Start, Prostart CT-3300
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71117
Printed Date: April 05, 2026 at 2:20 AM
Topic: 91 Regal, Remote Start, Prostart CT-3300
Posted By: 34gtp
Subject: 91 Regal, Remote Start, Prostart CT-3300
Date Posted: January 19, 2006 at 5:03 PM
I have everything hooked up but the car won't run. I'm sure it has to deal with the fuel pump not being turned on. The car will just sit there cranking and cranking. Anybody have experience putting a Prostart CT-3300 (from canadian tire) in a 91 Buick Regal? Everything else works, I'm stuck on this.
Posted By: kohara73
Date Posted: January 19, 2006 at 6:53 PM
That car has 2 ignition and 2 accesory wires. Did you hook all of them up? I know the ct 3300 does not come ready to wire all of those. You will have to use a relay for at least one of them. If you have hooked all them up, check to see that you haven't ran an acc. wire from your remote start to an ign. wire on your car. Are you using tach sense or voltage sense?
------------- Keith
Posted By: sparkie
Date Posted: January 19, 2006 at 7:39 PM
I agree with Keith. There is a pink and a blue/white ignition wire. There is also a orange and PURPLE / white accessory wire that needs to be powered up.
------------- sparky
Posted By: Velocity Motors
Date Posted: January 19, 2006 at 8:43 PM
Also, if the Regal has a small pellet on the shaft of the key, the vehicle has VATS. The wire information says that it doesn't but I haev done a few vehicles in the past where the wire information says that there isn't a anti-theft system on the vehicle and it did have one.
Also, did the tach programming get programmed properly ?
------------- Jeff
Posted By: 34gtp
Date Posted: January 22, 2006 at 1:40 PM
Ok, I hooked up the extra GREEN wire from the remote start. I used it for a 2nd ignition wire. I connected that green wire to the blue/white ignition wire. The car will now start via the remote. Do I haveto worry about the extra accessory wire (PURPLE / white) stated above? The car definately has no VATS Thanks for the help!
Posted By: kohara73
Date Posted: January 22, 2006 at 5:05 PM
Yes, you'll have to use a relay to power it though, because you're all out of high current outputs on your CT-3300
------------- Keith
Posted By: 34gtp
Date Posted: January 22, 2006 at 7:06 PM
Ok, I'm not sure how to wire in the relay then. Can you help me out with that? I have plenty of those GM Hella relays -------------
Posted By: kohara73
Date Posted: January 23, 2006 at 8:34 PM
It's just a regular 12V 30A relay you need. pin 85 acc. #1 pin 86 Ground out when running from your ct3300 pin 30 fused 12V pin 87 acc. #2 wire on your car That should do it. ------------- Keith
