2000 Mits Galant Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71228
Printed Date: April 02, 2026 at 9:51 AM
Topic: 2000 Mits Galant Remote Start
Posted By: vmuschler
Subject: 2000 Mits Galant Remote Start
Date Posted: January 21, 2006 at 3:25 PM
I have installed the remote starter, but am having trouble with the door unlock/lock.  I have the new remote working the locks, but when used to unlock the vehicle it is setting off the factory alarm, according to wiring diagram I used I should have a ylw/white wire at the kick panel to disarm (not locating it), I am also having trouble hooking up the horm chirp?
Posted By: Mike M2
Date Posted: January 21, 2006 at 4:54 PM
According to DEI, the disarm wire is red in the drivers door harness. Horn should be light green in the column, no relay is needed.
Mike M2
Tech Manager
CS Dealer Services
Posted By: KarTuneMan
Date Posted: January 21, 2006 at 6:34 PM
MITSUBISHI, GALANT, 2000, Factory Alarm Disarm
When doing remote start on vehicles with factory alarm, must also interrupt the blue/red (-) key sense wire at the steering column using the status output wire to bypass the factory starter kill.
close
Factory Alarm Disarm red   -  drivers door harness
Date Posted: January 22, 2006 at 9:38 PM
thanks I will not be able to work on the vehicle till next weekend, but thank you
