bitwriter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71246
Printed Date: April 01, 2026 at 9:34 PM
Topic: bitwriter
Posted By: mobilecustoms
Subject: bitwriter
Date Posted: January 21, 2006 at 9:04 PM
is there an instruction manual for the bitwriter 998t and the 2.2 chip? I just got one today and dont really know how to use it.
Posted By: leades12
Date Posted: January 21, 2006 at 9:55 PM
look in the downloads section (to the left under general info) covers the basic operation of the bitwriter, Hope this helps
------------- Les
Posted By: auex
Date Posted: January 22, 2006 at 12:11 AM
It is really pretty simple.
Plug it in, turn it on, hit read, then hit the up and down arrows to highlight the option, hit select to change the option, then when everything is set up the way you want it hit write, when it pops up the next screen hit select a couple times to change the remote to 0(0 programs all remotes) and then hit write again.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: January 22, 2006 at 7:47 AM
i looked ther but did not see it
Posted By: leades12
Date Posted: January 22, 2006 at 8:06 AM
try this
998T------------- Les
Date Posted: January 22, 2006 at 8:45 AM
thanks, but the link does not work
Posted By: kgerry
Date Posted: January 22, 2006 at 8:47 AM
have you actually tried to use it??? you plug it in, turn it on, and off you go...... it's so simple to use a chimp could do it.... use the up/down arrows to move up and down the menu and the BIG button in the middle to change selections....
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Date Posted: January 22, 2006 at 8:48 AM
i have, but like the owner recognition part of it, how does that get programed?
Posted By: leades12
Date Posted: January 22, 2006 at 8:50 AM
hmmm, it's on page 2 of the downloads in general info
------------- Les
Date Posted: January 22, 2006 at 8:18 PM
thanks a lot... i totally missed that!
