2005 infiniti qx56
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71294
Printed Date: March 31, 2026 at 5:36 PM
Topic: 2005 infiniti qx56
Posted By: DBFORDTECH
Subject: 2005 infiniti qx56
Date Posted: January 22, 2006 at 6:00 PM
Hello,
I am installing a remote starter in a 2005 QX56.  Everything is working great, except that I cannot remove the drivers door panel.  I know some of you are shaking your head and saying "WHAT??!!" but its true, I need to remove the panel for access to the module in the door, but the panel is being held by 2 (bolts?) on either side of the inside door handle.  I expected to find bolts or screws there, but I cannot seem to gain access to them.  There is a piece of plasic with a wood like finish on the handle that may be covering them, but the plastic piece really resists removal...Im scared of breaking it, and in the past I have found that something that really resists removal usually isn't meant to be removed.
So, If anyone has every removed a door panel on a 2005 QX56, PLEASE HELP!!!!
Thank you,
DB
Posted By: JWorm
Date Posted: January 22, 2006 at 6:28 PM
I'm assuming you are trying to get to the doorlock wires. Do it without taking the door off. Read here:
https://www.carsound.com/UBB/ultimatebb.php?ubb=get_topic;f=3;t=002070#000000
Your 2005 should be the same as the 2004 listed at the top.
Date Posted: January 22, 2006 at 8:54 PM
Thank you Jworm....Great info.
You saved my day (lol!!)
Posted By: Chris Luongo
Date Posted: January 22, 2006 at 11:29 PM
By the way, the "door module" is just the power window switch.
On maybe 90% of Nissan products, the window switch can simply be pried out.
If you do choose to run wires into the door for whatever reason, I recommend making your connections very close to the window switch.
That way, if you have a failed connection and the car comes back for repair, you don't have to take the whole door panel off again.
