2003 Nissan Frontier 4-door
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71353
Printed Date: March 30, 2026 at 3:00 PM
Topic: 2003 Nissan Frontier 4-door
Posted By: dessie2222
Subject: 2003 Nissan Frontier 4-door
Date Posted: January 23, 2006 at 2:46 PM
I need a more detailed alarm diagram for a 2003 Nissan Frontier 4 door. Previous post on subject a little hard for follow.
DAC
Posted By: mo12v
Date Posted: January 23, 2006 at 8:09 PM
https://www.directechs.com/directwire/wire_body.asp?action=select&yr=5455&product=Remote Start
and
https://www.directechs.com/directwire/wire_body.asp?action=select&yr=5455&product=Security
or
Constant 12 voltsGREENIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ WHITEIGNITION SWITCH HARNESS
StarterBLACK / YELLOWIGNITION SWITCH HARNESS
Dome LightGRAY/BLACK (-)DRIVERS KICK PANEL
Trunk Pin Switch
Parking LampBLUE/RED (+)AT HEADLIGHT SWITCH
Power LockGREEN/ REDDRIVERS KICK
Power UnlockBROWNPANEL
Negative Pulse Door Locks
Accessories
Window Up
Window Down
Ign Key WarnWHITE/ GREEN (+)IGNITION SWITCH HARNESS
Trunk Release
OEM Horn
Headlights
OEM Alarm Arm
OEM Alarm Disarm
Oem Hood Trigger: BLACK/ PINK (-) Drivers Kick Panel
Remote Start
Tach SignalPINK/BLUEAT IGNITION COIL
Ignition #2RED / YELLOWIGNITION SWITCH HARNESS
Ignition #3
AccessoryWHITE/ BLUEIGNITION SWITCH HARNESS
Neutral SafetyYELLOW (-)AT RELAY CENTER UNDER HOOD
Brake LightBROWN / RED (+)AT SWITCH ABOVE PEDAL
Reverse LightYELLOW/RED (+)DRIVERS KICK PANEL
Rear Window Defrost
Immobilizer Bypass
MO
