central locking kit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71428
Printed Date: March 28, 2026 at 6:53 PM
Topic: central locking kit
Posted By: fiesta_forever
Subject: central locking kit
Date Posted: January 24, 2006 at 3:04 PM
hi all, im new to the site, my name is danny, i have a ford fiestaon a M reg 1994 , ive just fitted a shark car alarm as i cant really afford much else, and i have a central locking kit for it, the car alarm has one output wire for the central locking and the central locking has a lock and unlock wire.
i was told by maplins, which is where i got the alarm and central locking kit from that i needed a 5 pin relay switch now i no that i put the central locking output wire from the alarm into the input on the relay, and that the lock wire goes on one side and the unlock wire goes on the other side, but what 2 wires go into the coil to make the whole thing work??????
please i really really really need your help.
thank you
Danny :D
Posted By: mo12v
Date Posted: January 24, 2006 at 4:54 PM
If you are using 2 wire Actuators
You will need 2 SPDT ( Single Pole Double Throw ) Relays:
posted_image
If you are using 5 wire Actuators, then you probably have built in Lock / Unlock Switching and you will need a Relay to Switch those also
MO
Date Posted: January 25, 2006 at 3:52 PM
i am using 5 wire actuators, so how will i need 2 wire it up????? i think i read in the instructions sumwhere that the central locking kit is ground active????? what ever that means im not sure??? wot will i need then in total to work this system.
thanx
