2002 grand am remote start/keysense wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71485
Printed Date: March 27, 2026 at 12:42 PM
Topic: 2002 grand am remote start/keysense wire
Posted By: stiney
Subject: 2002 grand am remote start/keysense wire
Date Posted: January 25, 2006 at 3:14 PM
I'm installing a Code Alarm 425/535 with a plxr to bypass the passlock in a 2002 grand am gt. First, is it necessary to connect the keysense wire on the plxr, and if it is, what color is the wire in the car? Second, do I need to use relays for the locks eventhough there are on board relays in the brain? Third, what color wires and polarity for the headlights and horn? Thanks in advance for any input.
Posted By: kgerry
Date Posted: January 25, 2006 at 3:21 PM
you dont need it....
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: stiney
Date Posted: January 25, 2006 at 3:34 PM
Thanks for the info Kevin. Do you know about the locks,headlights, and horn?
Posted By: kgerry
Date Posted: January 25, 2006 at 4:07 PM
dont need extra relays if the brain already has them built in.... and horn and headlight can both be grabbed at the BCM, both are -.......
Owner/Installer
Classic Car Audio
since 1979
