Door lock light not turning off any suggestions...
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7178
Printed Date: April 01, 2026 at 11:31 AM
Topic: Door lock light not turning off any suggestions...
Posted By: cavyinthegarage
Subject: Door lock light not turning off any suggestions...
Date Posted: December 26, 2002 at 5:33 PM
I have a 2001 ford explorer sport track, I used the 451 m to operate the door lock which works good.. but the door lock buttons in the vehicle stay on... so I disconnected the 451m and went back to stock until I figure this out...
so the alarm is a sidewinder 5000, I used the violet wire for the door trigger and ran it to the positive BLACK/ BLUE wire for the dome light..
can anyone help me solve this?
thanks sahwn
Posted By: Velocity Motors
Date Posted: December 26, 2002 at 5:40 PM
When you mean " .. but the door lock buttons in the vehicle stay on... " does that mean that the light is on or does that mean that the actuator stays locked and you can't unlock it because it is still on ?
Date Posted: December 26, 2002 at 7:27 PM
I mean the door lock lights inside the vehiclke stay on... the doors un lock and lock great...  it seems the light may be connected to the door trigger or something and the alarm is sending power to the door lock button lights?  sorry for the confusion...
Date Posted: December 26, 2002 at 7:30 PM
when I open the door the domelight comes on and the power door lock button lights come on... then when you shut the door it turns off 5 minutes after the door shuts...
my problem with the alarm is when using the 451 the door lock lights from the button are on all the time...
hope I explained it better?  If you need more info please tell me and ill try to explain better..
thanks
Date Posted: December 28, 2002 at 7:53 AM
anyone?
Date Posted: December 28, 2002 at 9:47 AM
How long after does the light stay on ? Have you actually timed it ? The reason why I ask is because the Ford uses a GEM module that retains power in the circuit upto 45 minutes and then cuts the power off to save battery and then you need to wake up the GEM after the fact. Can you please email me ( techsupport@velocitymotorsport.com ) the wiring diagram that you have for the 451M module so I can see what connections go to where on the unit ? Thanks and hope i can help you out.
Date Posted: December 28, 2002 at 10:35 AM
well i timed it for 20 minutes with the 451m.. let me re hook everything up and see how it works.. I will emial if it doesnt shut off... thanks
