clifford concept 650
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71805
Printed Date: March 20, 2026 at 4:17 AM
Topic: clifford concept 650
Posted By: b21playa
Subject: clifford concept 650
Date Posted: January 30, 2006 at 2:39 AM
Hi all,
Im looking for a specific wire on my concept 650.
It has to send a negative output when the alarm goes off, this is to activate a mobile phone to send a text message. it has to be a latched signal not pulsed.
If anyone could heelp me that would be great.
Thanks in advance
B21playa@gmail.com
Posted By: b21playa
Date Posted: January 30, 2006 at 2:51 AM
ive read the concept 550 manual and it has a output for the honk horn and has 2 settings, puulsed and latched but if its latched the horn sounds when arming/disarming the alarm, and if its pulsed it wont work with the unit..
is there any way to changed a negative pulse output to a negative constant output
Posted By: redpeppers
Date Posted: January 30, 2006 at 3:04 AM
check the programming settings in the manual and see if u can shut the chirp setting to off.  Then the horn output would only send out a negitive trigger when the alarm has been triggered.....u will have to turn it on latched.
Where theres is a wire there's a way.
Posted By: b21playa
Date Posted: January 30, 2006 at 3:34 AM
Yeah i think there is a setting to turn it off
Posted By: b21playa
Date Posted: January 30, 2006 at 3:37 AM
just thought about it, and the thing is the alarm chips if anyone gets too close, as i have a proxy sensor on it so i dont thinik it will work
Posted By: b21playa
Date Posted: January 30, 2006 at 5:50 AM
or does the siren itself have a wire that goes constant negative when triggered
Posted By: Powermyster
Date Posted: January 30, 2006 at 1:00 PM
you can use the horn trigger on constant and program it not to trigger with chirps. that will work fine.
Why oh Why didn't i take the blue pill
Darren Power
Posted By: b21playa
Date Posted: January 30, 2006 at 1:10 PM
the thing is it will not chirp with the proxy sensor either
Posted By: b21playa
Date Posted: January 30, 2006 at 1:53 PM
if not is there a circuit i can use to change pulsed signal intoa constant one
needs to be negative input and negative output
Date Posted: January 30, 2006 at 5:04 PM
yes you can use a timer relay for the prox warn away
Darren Power
