Remote Start 1999 Pontiac Grand Prix SE
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7181
Printed Date: March 27, 2026 at 1:07 AM
Topic: Remote Start 1999 Pontiac Grand Prix SE
Posted By: eugenenet
Subject: Remote Start 1999 Pontiac Grand Prix SE
Date Posted: December 26, 2002 at 6:05 PM
Help! I have a Grand prix SE 1999. I  installed an alarm with remote start. I need to know where i can find white or violet/white tach wire. I called to support of my alarm and i got two different places. Also, please advise which wire should i use.
Thaks a lot!!
Posted By: Velocity Motors
Date Posted: December 28, 2002 at 11:28 AM
Use either one. One will give you a stronger and cleaner signal than the other, but you can use either one. Just try it and learn the RS unit to the target wire, then test the starter. If the starter drags or the start duration is too short, use the other wire.
TACHOMETER-------------white-----------------pin 8, conn. 2 @ PCM ( The PCM (Powertrain Control Module) is in the air cleaner assembly.)
The PURPLE / WHITE wire is also located in the plug as well.
Date Posted: January 01, 2003 at 8:13 PM
Thanks a lot. I tried white wire ( in air filter housing  - ECM - pin 54). It works.
Thanks a lot!!!!!!!
Posted By: installa
Date Posted: January 02, 2003 at 1:44 AM
you can always just go to the injector ,
Date Posted: January 02, 2003 at 1:18 PM
Well, I found white wire in ECM (i knew it's pin54) then traced it to ignition module and taped in there.
Thanks a lot
