97 Suburban Factory Keyless
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7218
Printed Date: March 26, 2026 at 7:26 AM
Topic: 97 Suburban Factory Keyless
Posted By: mrplow
Subject: 97 Suburban Factory Keyless
Date Posted: December 27, 2002 at 12:53 PM
I installed a Viper 550esp in my 97 GMC Suburban.  Everything works great.  I just need to know how to either disable the factory keyless entry or deprogram remotes from the factory keyless.  I borrowed a remote from a freind to use till I got the alarm in and now I want to deprogram it from my Suburban and program it into his Suburban.  I know how to program them in by shorting the 4th and 8th pins on the ALDL plug under the dash.  So I tried shorting the pins and then not learning any remotes in, but that didn't work.  Any and all help or suggestions will be appreiciated.  And like I said I will disable it if I have to.  Thanks in advance.
Posted By: mrplow
Date Posted: January 07, 2003 at 8:18 PM
WOW!  not everyone speak at once.
Posted By: Velocity Motors
Date Posted: January 07, 2003 at 11:33 PM
Only way to deprogram the OEM FOB remote is to replace the current code with another one from another remote FOB.
Posted By: mrplow
Date Posted: January 07, 2003 at 11:59 PM
Thank you very much for the info.
