Omega bypass works intermittently
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72220
Printed Date: April 24, 2026 at 5:09 AM
Topic: Omega bypass works intermittently
Posted By: tarasdad
Subject: Omega bypass works intermittently
Date Posted: February 05, 2006 at 8:11 AM
Has anyone had this problem before. 2000 town car-crimestopper rs900 VII remote start with omega IB-F1 keyless transponder bypass. I programed the bypass correctly, sometimes when i remote start the car it starts fine, sometimes it just cranks and security light blinks. I have replaced the transponder bypass twice but still does the same thing. This car is driving me nuts.
------------- Never be too busy chopping wood to take time to sharpen your axe.
Posted By: mo12v
Date Posted: February 05, 2006 at 11:27 AM
I assume you have IB-F1 BROWN wire hooked to Yellow / Black on R / S Double check the YELLOW / Black wire on PIN 3 of CrimeStopper. Be sure it is programmed for ByPASS..(Negative Output During Cranking & While Running ), & not Anti-grind Also check Ground from IB-F1.......Be sure of good Chassis Ground
------------- MO
