2001 Camry, Best place to put alarm ECU?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72586
Printed Date: April 19, 2026 at 5:20 AM
Topic: 2001 Camry, Best place to put alarm ECU?
Posted By: iceohio
Subject: 2001 Camry, Best place to put alarm ECU?
Date Posted: February 10, 2006 at 5:45 PM
I'm installing a Bulldog 500 in my 2001 Camry to replace a cheaper one.  Although the cheaper one is the same size, I really don't like where I installed it.   Sadly, it is e-taped to the wiring harness...
Anyone have a suggestion of a safe place to put it?  In my Jeep I pulled the instrument panel out and it fit perfectly under there.   Jeeps are already easy enough to get into... I was happy to know I could put the ECU someplace that would require more than 30 seconds for a common thief to get out.
Thanks!
Joseph
Posted By: iceohio
Date Posted: February 11, 2006 at 3:14 PM
Sorry.. I didn't mean ECU, I meant the alarm unit itself.  I guess that would be BCM (as Alert calls it).
Joseph
Posted By: KarTuneMan
Date Posted: February 11, 2006 at 4:11 PM
Theres LOTS of room behind the fuse box...
Posted By: iceohio
Date Posted: February 15, 2006 at 11:45 PM
Thanks!
That's where I put it.  Plenty of room for the box, relays, and almost for me to crawl up there. :)
Joseph
